Re: Should prop turn while cranking?
It may just be tight gears, which is a good thing. To test for neutral, try to turn the prop by hand in neutral,ignition key OFF, Lanyard switch key PULLED.. If it turns,but doesn't turn the motor,it is in neutral. If the flywheel want to turn too, it is definately in gear.
