Re: Should I trailer with outboard down or up?
THe way that I see it, an outbaord is heaviest at the powerhead (top heavy). And the pivot point is directly below the power head. So the pivot point is pretty much the balanceing point on an outboard (or as close as they could reasoanably get for engineers). Therefore, if the pivot point is where the tilt locks are located, then this is the best place for support, if it is done right.<br /><br />I trailered for years, but untill I saw an outboard mechanic do the following, I never thought about it. When you tilt up you outboard and flip the tilt locks, don't just lower the motor till the locks touch and expect that to be enough support. Lower the tilt until the locks touch, then let the motor continue to run until the trim pistons are retracted all the way. once they are in, the tilt piston will put an additional pull ont he outboard locking it in place. (Once it pulls, let off. I am not advocating anyone burning a trim motor up) This will lock the outboard down on the motor mount and aleiviate any bouncing, therefore saving your transom.<br /><br />Knightgang
