Should I paint these?
BigB9000
Do I need to paint the bases & top of the rubber mount things?
1946Zephyr
Re: Should I paint these?
I would at least apply a good coat of zinc chromate on them, to keep them from rusting. It also wouldn't hurt to paint them with a coat of the same color your motor is.:cool:
BigB9000
The last motor I did, I rustoleum'd them black. Wasn't thrilled by how they turned out, Ill paint them come the morning.
What about the hardware? I sandblasted it all clean too, paint?
1946Zephyr
I would buy new stainless hardware. Use anti-seize when you put it all back together.
F_R
Originals were painted with zinc chromate, then the motor was assembled. Then the whole thing was painted. So, the color coat only got on the exposed surfaces. If you want to pre-paint the mounts and make it better than original---your choice.
jeffnick
White - so it's obvious when it needs attention again.
a70eliminator
Anything that's been bead blasted like that need painted or it will rust the first time it gets wet.
BigB9000
ok, no can do on the new hardware, WAY to expensive. Some of the special bolts on the thing are $60!
That would be way over my price range. Do you think by sand blasting the SS hardware, I blasted off some kind of anti-rust coating?
F_R
No stainless steel is all the way thru.
Some, repeat, some stainless steel has enough ferrous metal (iron) that it will develop a surface rust. That kind of stainless is often passivated, a process that removes the iron from the surface to prevent that surface rust. IF it were such a grade of stainless, blasting could have exposed more iron to rust. Yeah, I know, a lot of ifs and maybes here. Paint it and forget it.
1946Zephyr
You can get stainless bolts and nuts a lot cheaper at Napa ore Lowes
BigB9000
picture makes them look bad, but, I painted them body (?) color:
1946Zephyr
Nice job. Lookin good. We want to see pics of this nice motor, once you get 'er done.:cool:
