should i mix the gas when i go back out
dannyman3
i had the alarm come on when was comming back in, it would only beep when would gas it hard, it was below empty on gas, i burnt 30gal all day no trubble run great, just started beeping when would gas it hard, i dont know if something going out on the oiler, or it was becase it was out of gas, should i mix the gas before i go back out and if so what should i mix it, if the oiler isnt going out wouldnt want to foul the plugs running to ritch.1990 200gt
LubeDude
Re: should i mix the gas when i go back out
Probably just need to fill your oil tank! When they get low that will happen!
dannyman3
its wasnt the oil tank it was the gas tank cant see any gas in it would it cause the alarm to come on
LubeDude
I realize that, but the alarm you are hearing is probably the low oil alarm!!
dannyman3
I realize that, but the alarm you are hearing is probably the low oil alarm!![/QU i just checked the oil tank and it was lower than i was thinking it only has bout 3/4 inch of oil in it that prob was the alarm i heard low oil thanks
kenmyfam
Top up the oil and fill the gas tank. Take a jug of oil with you next time out in case the alarm sounds off. Always wise to keep a jug of oil with you anyway in case the oil side of the pump decides to give out on you.
