Re: Should I buy the Johnson 4R70E opinions??
Thanks for all the great input guys. Went to look at the motor. It is in fact a longshaft, all linkages etc. are there, lower unit is in good shape, but sadly, the compression readings are as follows. 0PSI for the top cylinder. 60PSI for the lower. Someone had replaced one of the main motor gaskets with silicone, and it is a salt water motor, so the power head will need to be generously soaked in deep creep to make sure I dont break any bolts. I am going to take a deeper look when I get a chance. Either way, I got the motor for $25. The guy didn't really seem to attached to it, and I figured worst case scenario that one of my bud's on here would need some cheap parts, so if internals are not salvageable I will be generously parting the motor out. L/U is in pretty good shape, prop is near flawless, cover is a little faded, but no breaks or punctures, carb looks immaculate, rope start is in great shape, and flywheel looks great. If internals look okay I may do a full rebuild, we'll see!
