Shotgun Shells
jsfinn
Can someone please explain the difference to me between target load, buck shot, and bird shot?<br /><br />If I wanted to keep something around the house for small yard pests or home protection, would target load be good enough? The price sure is right.. :)
D
DJ
Guest
Re: Shotgun Shells
Sure,<br /><br />Target load can be determined, usually, by the amount of shot in the shell. Target loads are usually heavy on shot and light on powder. Shot is not much larger than a half grain of rice. They're usually #8 or #9.<br /><br />Buck shot is,usually, large pellets (about 12) in a shell. They are typically about .38 cal. each. On the guage scale, buckshot is "00".<br /><br />Bird shot is all over the board. It depends on what your hunting. I use #6 and #7-1/2 for Pheasant and #2 and #4 for waterfowl. # 8 and #9 for upland birds such as Grouse and Dove.<br /><br />Typically, the difference between target loads and hunting loads is the percentage of powder (read power) as opposed to shot.<br /><br />If you're blasting "clays" all day, you do not want to get beat up by high power shells. Target shells have small shot and lots of it.<br /><br />If you're actually shooting at live game, you never feel the recoil. Thus, lot's of power and as much shot as can be packed in. Shot size, again, depends on the game.
PierBridge
Re: Shotgun Shells
HMMMMM.....I thought you from down south DJ.....sounds like you are from MN,WISC or MI?<br /><br />Minnesota grouse opener is Saturday. :) :) :)
kenimpzoom
Re: Shotgun Shells
For home protection, buckshot works perfect. You can get 5 shells in a pack, will last forever.<br /><br />For killing varmints, the cheapest shot will be fine.<br /><br />Ken
D
DJ
Guest
Re: Shotgun Shells
Pier,<br /><br />I am originally from Michigan. I reside in Arizona now.
jsfinn
Re: Shotgun Shells
That's what I needed to know. Thanks everyone.
KRS
Banned
Re: Shotgun Shells
Originally posted by KenImpZoom:<br /> For home protection, buckshot works perfect. You can get 5 shells in a pack, will last forever...<br />Ken
I sure hope it does... otherwise find a new neighborhood!!! :)
jsfinn
Re: Shotgun Shells
:) ..I've never had a problem and I don't have any fear of a problem. I just learned in the Boy Scouts to always be prepared. :)
