h2onxs1956
Thread starter- Joined
- Dec 1, 2011
- 31
I have a Duranautic Offshore 14 '. Transom height = 17 inches. Max motor rated at 30 hp.
The transom plywood had rot. I removed it and went back with HDPE instead of plywood and added an aluminum plate inside to "samdwich" the HDPE to the exterior transom. And re attached that to their floor attached "kicker" angle.
Item 1 What are your thoughts on going to a larger hp motor. the fresh transom is far superior to the original.
Item 2 I am only finding 30 hp to 50 hp motors in the "long shaft" version. most shaft lengths at 20 inches.
DO they not make Short Shaft motors larger than 25?
Is their a data base about number of SS or LS manufactured/sold?
