Shore Power Only?
scatgo
Is that black box a power inverter? It has both batteries wired to it and 110 v AC input. When I plug in the boat to 110 AC the the refrigerator and air conditioner work but not off the batteries.
dubs283
Most likely that's the AC converter (battery charger)
An inverter would have cable (4-2 ga) connections from the battery bank
alldodge
Agree most likely a Bat charger
The AC and Fridge are 120VAC only so they won't run of Bats. You could replace Fridge with a AC/DC type
scatgo
If you take a look at the shore power panel there are 5 switches. One is marked converter. Anyone have a clue as to what a converter is ?
dubs283
Did you even read the two replies to your original post?
The converter is the on board, hard wired battery charger that is pictured in your post
Spoon feed: the converter, i.e. alternating current converter uses alternating current (input from shore power) and converts the alternating current sine wave to direct current to charge/maintain the battery(s)
scatgo
Thake your attitude and shove it [deleted].
MOD Edit:
While I agree dubs should have been more respectful, it's best to let it go
