tubenewb
- Aug 10, 2010
- 86
Hey all...In another post I started digging into the x-19 a little...While I dont disagree that the entire boat needs to be gone through for any long term use, I think I can safely get away with what I have this season..
It looks as though the majority of the deck was not covered in glass..In the rear deck area of the boat the only glass I see is an 8" strip on the transition from chine/hull area to deck.. Everything in between was unglassed and covered up with carpet/including the tank cover(middle deck area).
At this point I have only found little water damage in a foam float box(above the deck) and the surounding deck apx 12"X48".. all port side.. My intention is to rebuild the float foam box and the surounding section of deck ..(all 1/2" ply)
From what I have been reading (correct me if I am off please) it seams I am going to be using unwaxed poly resin...
Covering my plywood with a min of 1.5 csm then 6 oz cloth..
My main sections of this patch are 1.) 3 boards (foam box)port stern corner 2.) 12" X48" deck board and last 3.) the tank cover (made up up two 1/2" pieces sandwiched together)
My first question,
Is covering boths sides of all these pieces with the csm/cloth combo overkill ?
My next question is on tape..Is tape needed for all seams/transistions or can I use the 6oz cloth ? I am guessing the tape is just about the same stuff cut up for application purpose.
I am still reading many posts and searching things out. I am getting ready to make an order and just want to be sure I am not missing anything ..
For what I am doing I dont think I need any thickeners or fillers..
Thanks in advance
My first question,
Thanks in advance
