Re: Ships Ground on fiber glass boat.?????
This is all about semantics. Depending on the size of your boat, this could be the negative buss, or a seperate ground buss, that is somewhere tied to the negative buss. In most cases, if you have other electronics in close proximity, just run it to the metal case or ground of that equipment.
