Shifting issues - 1983 Johnson V4 jet drive
ritzkraken
Motor starts up and runs great - shifts into forward and reverse easily. However, once I have shifted into reverse, it becomes locked out of forward and neutral. Shut the engine off, start it up, and it shifts back into forward (the lockout does not happen when not running). I have adjusted the throttle cable and lowered the idle speed, but the problem still persists. Of note - I do not get much throttle in reverse, even with the shifter bottomed out. Seems like it is a remote/control box issue, and I have taken that apart, but everything looks good. Any ideas?
Thanks in advance.
