I recently broke down and cleaned the carbs on my 1999 Honda BF25A to correct a stall/ rough idle issue.  I also replaced the impeller as a maintenance item.
When I did the impeller I took great pains to return the nut on the shift linkage to the exact position I found it down to the thread. However, when sitting in neutral at the shifter I am actually in forward according to the gear box. I have tried to adjust the nut on the shift linkage just above the lower unit, but it really does not seem to effect the shifting process.
Is there an adjustment topside in the engine compartment for shifting adjustment?
