frenchie12
Thread starter- Joined
- Jul 1, 2008
- 1
Doing some interior work and took the throttle handle off. When I put it back together it wasn't quite right; the disk for the safety pin was off, the boat shifted fine if the handle was moved quickly but if it was moved slowly the gear would grind or would not go in gear. I took the handle off again, I put the disk for the safety pin properly seemed to shift a little better but still would grind if not shifted quickly. It has never had a shifting problem before. The outdrive has been serviced last year. Are there any adjustments that I should have made.
