Shifter
Tomboo
put up a pic. are you talking about the rubber hub?
No. Talking about steel teeth that are missing. Moot now. I am replacing the 94 lower unit with the 99. I understand, thanks to you, that means using the shift rod from the 94.
flyingscott
ok good because if the prop moved far enough to hit the torque tab that lower has way more issues.
