Shifter shaft cam 1973 50hp mercury
johnnyo34
I took the leg off my 1973 50hp Mercury. As I was working on it the cam slipped off the splines on the shifter shaft. Are there any pictures how this should be fitted so I can get it on correct?
Moody Blue
Re: Shifter shaft cam 1973 50hp mercury
Are you talking about the black plastic reverse lock cam that sits at the base of the shift shaft on the LU?
johnnyo34
Yes, mine slipped off the splined shaft when I was carrying it, & I want to put it back right..
emckelvy
Likely you're in FWD gear so just turn the shift shaft CCW to Neutral. If you turn the driveshaft or propshaft while you're shifting it'll go smoother. Use a pair of pliers cushioned with tape etc to turn the shift shaft.
Once you've located Neutral, turn the shift shaft the least amount possible in the CW direction that'll cause the gearbox to shift back into FWD. Leave it in that position, don't turn it any more in the CW direction.
If you're reinstalling the lower unit with the control box in FWD, this is the correct position for the shift shaft.
Now, you can install the reverse lockout cam. Take a look at the reverse lockout rod, sticking down from the center section. Note how the lockout rod will hit the shift cam. Position the shift cam such that the lockout rod will point towards the middle of the shift cam's ramp.
So what will happen when you shift to Neutral is, the flat spot at the top of the shift cam will block the reverse lockout rod from springing down. This keeps the reverse lockout hooks firmly locked around the tilt pin. When you shift to Reverse, the flat spot still blocks the rod.
Once you have the shift cam correctly installed, you can either leave in FWD and install that way, or shift to Neutral. Just be sure, if you shift to Neutral, that the control box is in Neutral also.
Some find it easier to line up in Neutral, you just need an assistant or long arms to turn the flywheel a bit to engage driveshaft with crankshaft on the way up. Be sure to disconnect the battery and pull spark plug wires when doing this work!
HTH & let us know how it goes.........ed
