Shifter linkage line up Evinrude 115
riversidetransmission
I bought a boat not running . Seller had removed lower unit to install water pump , and replaced fuel tank that was under the liner with one under the center console . He said had shifting problems because cables hit the new tank , but they look fine to me . It was leaking water from lower unit so I pulled it and found exhaust seals installed wrong (easy fix) . Now I can't seem to get the linkage rod to go back into that little hole on the piece going down to the lower unit , it just flops around. Motor is 97 115, HLEUA . Also cables were off when I got it , how do I adjust them ? Seems like the shifter handle at the helm has 2 detents rather than one for neutral .
Joe Reeves
I retired in 1991 so I'm not familiar with the shifting setup on your 1997 engine, however that shift rod screws into the lower unit, does it not? And if so, there is a certain measurement to consider that must be set in neutral between the top surface of the lower unit and the center of the shift rod hole.
V153
21 27/32" to be exact. Provided that's a 20" mid crossflow motor.
jakedaawg
Maybe post a pic, close and far, of what your talking about. Seems to me like on the engine side there is a hitch pin that allows linkage to slide letting you afix the upper end.
Then there is the rubber bushing at the cowl that it slides through...
Then there is the seal housing at the lower that it slides through..
Then it screws in the yoke...
