Shifter Cable problems - 91 90 hp Evinrude
winks33
I just recently replaced both of my shifter cables because it was very hard to shift the shifter forward, they also were very old. Without the cables attached to the engine the new cables move very smoothly. I tried shifting the forward linkage by hand and it didn't seem excessively hard to do, so I don't understand why it's so hard once he cables are hooked up? Could I have a bad drive problem? Any advice is welcome....
mick_eight
Re: Shifter Cable problems - 91 90 hp Evinrude
If this is without engine running ? If so, try with engine running and see if its the same.
winks33
It's without the engine running. Reverse shifts fine without the engine running though. I try it with the engine running tomorrow.
tashasdaddy
the clutch dog only has 2 teeth on it, they have to be lined up to shift, have some one turn the prop when shifting, it will slip right into gear.
