Shifter Cable Boot Replacement
jgermann
OK so here's my story.
Grew on living on the river my whole life, just bought my first boat this year. Its a 1995 Chapparal 1930SS with a 305 V-8 and a mercruiser alpha 1 outdrive. The boat is in good condition and we were out a few weeks ago and someone asked me why my boat was pumping out so much water. It had never taken on a drop of water the first month and a half that I had it out. It only takes the water in when the prop is up. I searched around the outdrive and noticed that the shifter cable boot it dry rotted and cracked. Is this a job that I could do it I get a manual? I have some experience working on cars and like ot work on things but I've never seen an outdrive off.
Also, if I do it or get someone else to do it, what else should I change or look at while it is apart? Oh yeah, it had a new shifter cable put on last year or the year before. Don't know why they didn't go ahead and replace the boot.
Thanks.
jerryjerry05
Re: Shifter Cable Boot Replacement
Who ever replaced your shift cable shoud have replaced the boot, just SOP on the shift cable repair.
You can do it your self.Get a manual and a friend.It will take some time just DON"T force it.Jerry
jgermann
OK, I just ordered a manual and it should be here in a couple days. Would it be smart to go ahead and get a bellow kit to replace all of them? And are there any tricks to keep in mind while replacing? I did hear something about puting in drive before removing outdrive.
jaxnjil
OK, I just ordered a manual and it should be here in a couple days. Would it be smart to go ahead and get a bellow kit to replace all of them? And are there any tricks to keep in mind while replacing? I did hear something about puting in drive before removing outdrive.[/QUOTE
YES it would be a good idea to change them all.
yes you put your out drive in forward to remove and install
will all be covered in manual that don gave you the link for
jgermann
Thanks for the link and advice. Hopefully will get it done without too much trouble.
JustJason
if your going to do all the bellows you might as well change the shift cable out as well.
