Lil Big Boy
Thread starter- Joined
- May 15, 2009
- 1
I have a 1979 Mercury 40HP and recently I had trouble with the F/R. I was running upriver and when I went to throttle back the shifter would not pull back into neutral or even go into reverse. I've disconnected the linkages and they move freely. I tried to turn the cam under the carb and that would not move, so I dropped the lower unit and discovered that the shift shaft does not move very easily, and I still could not get the prop to engage in reverse with the LU off. What could I be looking at here cost wise to have it repaired. I'm not sure if it's worth buying the tools to remove the shift shaft? If anybody can stear me in a cost effective direction I would appretiate it.
