1987 3.0 Alpha one. Is this normal for the shift shaft to have this much play in the bushing? Thanks
K Kolar Cadet Joined Jun 12, 2010 Messages 20 Jul 7, 2012 #1 1987 3.0 Alpha one. Is this normal for the shift shaft to have this much play in the bushing? Thanks
D dollarten Petty Officer 2nd Class Joined Jul 28, 2011 Messages 136 Jul 7, 2012 #2 Re: Shift shaft slop? Yes , that is the upper housing .The splines on the lower shift shaft , so to speak will line up with the upper one and hold the one you say is loose
K Kolar Cadet Joined Jun 12, 2010 Messages 20 Jul 7, 2012 #3 Re: Shift shaft slop? I just thought since there was a bushing in the upper case the diameter of the shift shaft would be close to the size of the bushing. What is the bushing for then? Thanx
