FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
The shift rod itself is not adjustable as it is held in place by a foot at the bottom of the shift rod.
The barrel swivel at the top of the shift rod should be turned down until gently seated, then turned up no more than two revolutions so that the flat surface [edit] faces the driveshaft.
Make sure that the nylon bushing is in the hole in the barrel swivel when you reconnect.
