shift rod
tav
Johnson. 40. 2 STk. (2004) where do you disconnect it when removing the lower end?
James R
Re: shift rod
The shift linkage is located under the carb. There is a screw that goes through the linkage and the shift rod. Difficult to see but look under the carb from the port side and you should see it.
tav
Re: shift rod
i'm at work now ....but do i have to remove front cover to get at it? should it be in forword or rev when removing it?
