Shift rod removal
futur49
Hi everyone. I am new on this forum and need your help. First let me say that I have read alot of post regarding my motor model & year. 1973 evinrude starflite 85hp 85393m model. Fantastic motor. I am searching for how to remove the shift rod from the lower unit (not from the motor up top,! From the lower unit) I have disconnected the rod from up top and have removed the lower unit with success. I am attempting to reseal all lower unit seal including changing the water pump n propeller. ( I'm assuming this subject has been covered extensively, but am unable to find the answer for my specific year model. Any help would be greatly appreciated). To clarify I have bought the original pmc bro water pump kit and original brp lower seal kit which should have all necessary seals between the 2 for the completion of the job. I have run into 2 problems. I will try to describe as best I can cause I do not know all part names etc... So far I have removed lower unit, propeller and water pump. I am cannot remove the the housing in front of the drive shaft where the shift rod sits in. I received a gasket for it but the gasket is for a longer housing with 6 screw holes where my model has a smaller housing with only 4 screw holes. That is the 1st problem. 2nd is that the shift rod to my knowledge cannot be unscrewed from the lower unit like most videos I've watched. Most videos say that models from year 73 to 77 is just unscrew the shift rod. Mine seems locked both right and left when I try to turn it. I am afraid to apply too much force. My lower unit is completely disassembled save for my shift rod and housing around it. I also dont have the proper gasket but that is the least of my worries cause j am sure I can find one fast. I believe I am able to reseal the entire lower unit but cannot do the housing around the shift rod since I do not know how to remove the shift rod. Can any one shed some light on the shift rod matter. That you in advance and sorry about my rambling.
Joe Reeves
That shift rod does not unscrew.... it simple locks into the shifter complex under that housing that is self explanatory one you remove the housing. Get the proper gasket first!
Note the the barrel looking top unit, to be exactly where it belongs must be screwed all the way down, than backed up to it's proper position. Also that small nylon bushing "MUST" be installed in the barrel or it will be impossible to adjust the shifting.
futur49
Thank you Joe for the help. So just to be clear, I can unscrew the top hook leaving the nylon bushing in place to remove the housing to change the gaskets inside the housing? I have the gaskets already. Just need to confirm the removal of that top hook before I can continue? It CAN be unscrewed from top to access the housing below? I have noted your reinstall of the hook! Thank you.
futur49
Just to correct my previous message. I have the small o ring gaskets that sit around the shift rod but not the gasket for the housing. Yes I will get that first! Thanks again Joe.
Joe Reeves
No need to unscrew that shift barrel.... You'll understand once you get the bolts out of the shift rod housing.
It's best not to remove the shift rod from the housing anyway as you do not want to be running the threads of the shift rod past the "O" Ring seal in that 4 bolt housing unless you really have to for some reason.
futur49
Will do Joe. Thanks for the help. Gasket will be here on tuesday. Have a good one. Will update on everything once the job is done.
