shift rod bushing removal, 1986 30hp
BAYDOG225
Is there a way or special tool (number?) to remove the shift rod bushing with out removing all the lower unit shaft and gears?
Newyota
Think I have seen where you could use a tap to thread brass bushing and use all-thread up thru a piece of steel and use that as a puller.
