Watermann
- Jan 12, 2013
- 13,860
Yeap you have to take that outer exhaust housing off and the inner as well since it will ruin the gasket they both use. Look up inside there with a flashlight and you can see where the tube goes. You also have to take the split ring off the bottom of that motor swivel to drop it down and off. You'll need a new gasket for that housing and a probably a new grommet for the water pipe.but I can;t seem to find one in stock any where I normally shop for parts on my old Johnny.
Greasy, grimey job but it's pretty easy.
Google the part number below
315861 ? GASKET, ADAPTER TO HOUSING
