Shift problems alpha one
affa
Hi
I replaced my shift cable on my alpha one gen 2, and it shifts fine into both gears, but it stays in gear a little while after I put it back in neutral.
Is that something to adjust as well?
Regards
Affa
Haut Medoc
Re: Shift problems alpha one
You need to see if your shift interrupt swich is functioning properly.....;)
affa
Hi, and thanks
I checked the cut-out switch, and it does work ok if I help moving the Y-plate a little bit, it looks like it is not enough movement in the Y-plate that should make it work properly.
any ideas?
regards
Affa
Haut Medoc
Well, the only time that the switch actuates is to allow the gears to disengage, so something is not adjusted properly......;)
You made sure that there was 153mm from the center of the barrel nut to the 'eye', while pushing in on the shift cable & turning the prop counter clock wise & ensuring it locks into gear?.........:confused:
Do you have a roller or plunger type switch, you will need to determine how much movement is required to actuate (close) the switch......
You need manual # 14, I'll see if I can find the link......:)
affa
ok, thanks alot
I`ll see if I can adjust the plunger switch.
Thanks again
regards
Affa
