Timlong791
Thread starter- Joined
- Sep 11, 2018
- 3
I'll start off with a bit of background. I bought the boat from Someone and I stupidly took his word on what was wrong with it and what wasn't. Anyway the engine needed a head gasket, replace the kill switch, and install the thermostat they removed. Along with various other things in the boat that didn't work He said did. The boat is a 1978 venture and the motor is a 115 force. After getting my Hands on it the engine runs great but I do have a few questions for you fellers that have more experience with boats. I am an automotive Technician so I am very mechanically inclined but still a newbie to real boats. My last boat I had for 10 years a 50's Jon boat I put a 50'a Johnson seahorse on but it was tiller operated and had none of this nonsense.
I am having trouble setting the linkage for the shifting. I have adjusted the ends of the cables and the nut on the shift rod shaft. I made super small adjustments to both checking as I go. I cannot for the life of me get it right. It only goes in one or the other but it is super close to getting the other. The cables aren't in real great shape, they are kind of frayed on the sheathing but it doesn't seem to hinder the movement. I thought about getting a universal control box that has adjustable throw but I'm Sure that there is nothing wrong with this control box and I'm Doing something wrong.
Other question is that on my control if you push it forward and it is at the 9 o clock position I would think that should be full throttle but it's more like 25% throttle and if I push it to about the 7:30 position that's full throttle, so that little bit of movement is 75% of my throttle control. Not sure if this is normal or not.
Thank you for any help. If you need more info or pictures of what I'm Talking about just let Me know.
