freddyray21
- Jun 10, 2006
- 2,460
picked this one up at a sale the other day and got it running yesterday. It will need an impeller and I have one ordered locally will be here tomorrow. No problem with the impeller change though. For the short time I had it running it seemed to want to go from neutral into gear by itself. It I held the gear shift it would not, but leaving it alone it would shift. I have another one of these motors also very similar a 1972 4hp and the shift lever is set in a different position. To explain, looking at the gear shift on the 72 from the side neutral is in about a 12 to 1 o'clock position. On the 64 neutral is in about the 3 o'clock position. When I dropped the lower unit to replace the impeller there was no shift linkage to unhook. Just the shift shaft lined up with grooves to it's mate. Is is possible some PO put the shift lever in the wrong position when they put it back together and that is why it wants to shift on it's own. I need to get this fixed as it needs to have a reliable neutral to be a usable motor.
