SHIFT LEVER REMOVAL 1982 JOHNSON 8 HP
maineiac5586
Master Chief Petty Officer
I need to replace the shift lever on my 1982 Johnson 8 hp outboard motor. I don't see how to remove it. I think there is a metal cap with a couple gears under it as I see in the parts breakdown. I don't know how to gain acess to that area. Can I replace the shift handle without removing the powerhead? Please help.
boobie
Please stick to one post on the same subject as it's less confusing.
nwcove
++^1....so much info gets lost in multiple posts on the same motor/issue.
Honorary Supreme Mariner
1984 is the first year for the 8 hp model.------------Might have to remove the carburetor to get that cover off.
maineiac5586
Ok I got it. Removed carb was able to sneak a 3/8 wrench in there and got the cover off. Removed the screw holding the shift handle in and swapped handles. Thanks for your time fellas.
