Shift Lever Adjustment
jbrow9.5hp
Hi All,
Is there a trick to getting the shift lever adjustment right? this is a 1965 9.5 hp evinrude sportwin. I had to undo the linkage to change out the impeller,and every since, the shift lever has been down a couple inches and it pops out of gear in forward if I go any faster than trolling speed. Its like reverse is now where Neutral is, Neutral is where forward was and Forward is even lower now...I cant seem to get the linkage right.
Thank you,
Joel
ezeke
Re: Shift Lever Adjustment
When you reconnect the shift rod sections, you have to completely remove the screw. This will allow the rod to be inserted far enough to allow the screw to hold the grooved section of the rod correctly.
boobie
Agreed. This mistake has been made many times.
cc67
Also, if you don't get the groove aligned properly you will destroy the threads on the screw.
