toolsinbox
Thread starter- Joined
- Apr 22, 2009
- 187
right hand drive alpha 1 gen 1.
when the shift leaver is pushed all the way back in the bell housing; what should the orientation of the upper shift shaft shoe be ? I took it apart to do the seals and can't remember which way the shoe is supposed to point. There are only two options. Any explanation that helps me get the shaft the right way around would be great.
Second. I installed a new lower shift cable and all went well until i went to put on the end cable guide. With my son on the prop; I gently pushed on the cable and spun the barrel to get to the 6 inches. Except I had to spin the barrel tword the cable guide all the way until I ran out of threads, then it was at 6 inches. I this normal?
The guide is threaded all the way into the cable; stop nut is tight; I thought there would be a few threads left to go less than 6 inches with the barrel?
thanks
thanks
