Shift interrupt switch
sas440
How maney cylinders does a shift interrupt switch cut out. If the switch is bad could it limit the number of cylinders firing while on the muffs in the driveway. Thanks Scott
Don S
Re: Shift interrupt switch
All of them, it basically shorts the ignition to ground.
No.
sas440
Thanks for the info. But if the switch is bad could it cause the engine not to fire?
DaveG55
Since the switch grounds the ignition then, yes, it "could" keep the engine from firing. I don't think it's very likely though. An Ohm meter will tell you in just a few seconds, it's a very simple check to verify/eliminate the switch. Check it real quick and then move on to a reasoned trouble shooting approach to the problem.
