Shift diode install on 100ESL72..Help??
backdraft33
Can anyone describe how to connect the shift diode in the control box? One wire is purple, the second wire is purple w/ green trace from the diode.Where do they connect?<br /><br />Model - 100ESL72R<br />Serial-J3700996
craigvalk
Re: Shift diode install on 100ESL72..Help??
I don't know the answer backdraft, but any service manual for that motor would show the wiring diagram and would probably set you straight.
Joe Reeves
Purple connects to the "Ign" terminal of the ignition switch. Purple/Green connects to the power (voltage) terminal of the shift switch.
backdraft33
Originally posted by Joe Reeves:<br /> Purple connects to the "Ign" terminal of the ignition switch. Purple/Green connects to the power (voltage) terminal of the shift switch.
Thank you for your help...It'll be great to get her back out on the lake.
