Shift Control Lever Removal
yagersmom
My husband asks:
How in the #@&%* do I remove the #@&%*-ing control lever without ripping the boat apart? The lever seems to be attached to the fiberglass and upholstery by about 5 screws which, upon removal, the thing only wiggles slightly. There must be a trick - or am I missing something? Thanks.
Andrew
bigbrownbuku
Master Chief Petty Officer
Re: Shift Control Lever Removal
don is right. its usually a grub screw set underneath. you may have to line up the access hole on the lever to see it.
yagersmom
yagersmom
Thanks. Found a grub hole. I'll investigate and post photos if needed. Just knew there must be a trick. Thanks, again.
bamadave
Is there a button you push in for the cold start position? On my Mercruiser, I have to pop that button off (usally breaks but is only a couple of dollars) to remove a nut behind it, the shift handle comes off to expose the mounting screws.
