Shift cable leaking water onto valve cover
SteveH_1919
Finally got the boat running.
I have had it running for less that 1/2 hr on the muffs with no prop AND stern drive not engaged.
But, water is leaking from the shift cable onto the STBD valve cover. The leak appears to be coming from cable where it attaches to the shift linkage assy.
Any ideas?
Thanks,
Steve
Bt Doctur
Re: Shift cable leaking water onto valve cover
The O ring for the water inlet got moved, dislodged.pop the drive off and recheck
SteveH_1919
Thanks for the reply.
Sounds like an easy fix.
Thanks again,
Steve
SteveH_1919
The O-ring for the water in let was indeed dislodged. It was laying in the bottom of the stern drive housing.
Put the O-ring back in place, again, with Perfect Seal. Let the sealer set up a bit and installed the drive.
No leaks.
Thanks
Steve
a70eliminator
There's probably no where else you could have got a spot on diagnostic like that, this is such a great forum!
69aerocraft
Replaced my shift and cable and had a leak issue. Found this old thread. Saved the day,. Thanks guys.
?Should you find yourself in a chronically leaking boat, energy devoted to changing vessels is likely to be more productive than energy devoted to patching leaks.?
― Warren Buffett
