59Hustler
Thread starter- Joined
- Jul 20, 2013
- 82
I have a 1976 70 hP Johnson looper that I cannot figure out how to get the shift cable installed on.I have put the transmission in forward as per the manual and bought new cable guides. The issue is that the casing guide contacts the bent out portion of the shiftlever that connects to the rod to the lower unit.
I thought at first it was because I had old casing guides that were too thick due to bing from the early sixties. So I bought the correct ones for this engine. I also replaced the set screws with allen set screws. all of this helped as I can now hook it up without the cable installed in the casing guide..
The manual states "Place remote control lever in neutral position. Place shift lever on engine in forward position by swinging bottom of lever toward front of engine. attach shiftcable casing guide to shift lever pin using washer and locknut supplied. (flat on casing guide must face lever)."
I have done that but the casing guide doesnot have enough room to get past the bent out part of the shift lever and slide onto the pin.
