ziggy
Thread starter- Joined
- Jun 30, 2004
- 7,473
hello....... i'm just wondering?
i replaced my shift cable on my 165 L6 last fall thru this spring. just got my shift cable hooked back up to the shift plate inside the boat..... seems fine. got f, n, r on dry land.
i didn't have shift issues prior to replacment
i've not adj. the remote contol cable
my shift cable stud sits at the bottom of the shift lever slot.
in f, n, and r. the cut out switch sits in the vally of the cut out switch acuateing arm.
guess my question it this, it regaurds the old style shift calbe vs. the new. the old style one has all this info on cuting the core wire and support tube to this demension and that. the new style cable is not designed to be cut or disassembled. so. is the 6" demension in fwd. from the brass barrel to the center of the stud my critical demension? can i assume ( man am i gonna get ripped for saying assume) that if i had no issues with shifting prior to teardown. that the old cable was at 6", if i set the new one to 6" in fwd. there should be no change and i will be hip....
side note. i'm leary of this shift cable adj. proceedure. it seems complex to me, and i've read the service manual over and over. i've failed at this adj. before on a different boat. maybe that one had shift cable issues. but it ended up at a dealer and he got it set proper. so, i musta failed in that attempt. hence my reason for being leary of this adjusment. any insight?
