shift bracket 4.3 0k009133 exhaust manifold
tashasdaddy
changing from batwings to manifold and riser. seems like i saw a bracket somewhere, to mount the shift assembly on. can't reemember, ok i thinks it is a riser bracket, where can i find one. engine is 1997
Re: shift bracket 4.3 0k009133 exhaust manifold
If your Shift Bracket looks like This 1,.......<br /><br />It bolts Directly to the 3 cast bosses on the side of the Riser.........<br /><br />
<br /><br />The bosses are visable in this pic....<br /><br />
<br /><br />2 on the back edge,+ 1 near the leading edge/retaining stud area of the Riser.......
tashasdaddy
thanks bondo, thats just what i need to know, the sent manifloids w/ 3" riser and i order 4"riser. so i installed manifold and waiting on 4" riser to be delivered. Change plugs while i was at it.
tashasdaddy
Who ever suggested using long studs helped greatly. i had some 1/4" round stock cut 2 12" pieces put them thru the end holes in manifold, give you just the leverage to make a hard job easy.
Originally posted by tashasdaddy:<br /> Who ever suggested using long studs helped greatly. i had some 1/4" round stock cut 2 12" pieces put them thru the end holes in manifold, give you just the leverage to make a hard job easy.
Ayuh,...... Those holes are tapped 3/8ths"X16.....<br />I've got a couple old pc.s of Redi-rod for that purpose.......
