shear pin
josh18
My motor is in between 52 and 55 johnson 5hp outboard and my shear pin busted the other day what size do i need to replace it someone please help me out??
F_R
Part number 302333. It is a "drive pin", probably stainless steel and should not shear. A slip clutch built into the lower unit protects the drive train. Edit: Yep, just checked 3/16" x 7/8", SS​
josh18
Cause i was going across the lake the other day and hit something and the prop would just spin so I took it off and only thing left was what was inside the unit of the pin
F_R
As I said, the correct DRIVE pin would not have sheared. I'll bet somebody put a brass one in there, right? That's ok if you enjoy changing pins on the lake. Or rowing back home.
F_R
Any local Evinrude dealer can order them for you. Or on-line dealers selling genuine Evinrude parts. Or guys selling antique outboard parts. www.penn.it.go.com is one such source. ( douglas.penn@gmail.com ) Or if you have a decent hardware store in town, just buy a piece of 3/16" stainless steel rod and saw off a piece 7/8" long. I'm not going to tell you to use a nail, but we all know it happens. But if not the right diameter, it will wear the hole.
josh18
With that stainless steel rod after I cut it would i have to hit it with a hammer to get it in there or should it just slide in
nwcove
if you have to hammer it in.......there is a problem, so dont do that.
Gibsonman2005
any hammering in that area I think is a bad idea. F_R knows his stuff. Follow his advice. There should be a cap that keeps the drive pin from falling out and a cotter pin should go inside the cap through a separate hole in the cap that lines up with a second hole in the shaft. Cotter pins are cheap. In my opinion get 2-3 cotter pins and keep them on the boat and make a spare drive pin while you're at it and you have the metal and the tools out.
Gibsonman2005
You can bevel the edges slightly with a file to clean up the cut on both ends of the drive pin.
josh18
So I put in a new drive pin ran it yesterday for about a hour stopped did some fishing and now it seems like the flywheel don't wanna turn to start up someone please help
