sharp knives
ciolekr
I am looking for information on how to sharpen my fillet knives. everything I have tried so far has not worked out as good as a knife that has been professionally sharpened
Terry H
Re: sharp knives
I've never had any trouble sharpening filet knives or any other quality knife, but to explain it without pictures just won't work. I've tried to teach a few friends how, and some have the knack and some don't. Maybe if you do a google search on knife sharpening you will find something. just a thought :)
Bigfun
Re: sharp knives
The key is to keep the angle consistant throughout all your strokes. <br /><br />If the knife is very dull I use circular motions untill it is kinda sharp.<br /><br />Then finish by always pushing against the edge.
fixin
Re: sharp knives
practice practice practice(be one with the knife) :D :D :D
jimr
Re: sharp knives
I have a lansky sharpener for my knives and my filet knife is the hardest to do but if i take my time it works ok would work better if i had the diamond hones
ED21
Master Chief Petty Officer
Re: sharp knives
I like ceramic crock sticks held at the proper angle in the base. The flimsy blade makes it a bit tougher on fillet knives, but it can be done.<br />Clean the sticks w/ Comet when they get filled up w/ metal from the blades.
BoatBuoy
Re: sharp knives
From Feb. 1977 Popular Science, Sharpening Secrets of a Pro, by John Juranitch. How to sharpen a knife: Keep your hone from moving by putting it on a soft piece of rubber or tacking small pieces of wood around it. Use a Razor Edge guide to establish the proper angles for primary and secondary edges, or try this trick: Fold one 90-degree corner of a piece of paper in half. Fold in half again, and you have 22.5 degrees. Hold the blade at this angle or slightly less for your primary-edge face. Fold the paper again and you get 11 degrees. This is the angle you should use with the coarse hone for the secondary edge. Use whichever motion you prefer, back and forth or circular, being very careful to hold the angle constant. If you have trouble knowing when the burr forms, check with a magnifying glass; once you see that curl you'll learn to feel it with your fingernail. When you go to the fine hone to form the primary edge, stroke the knife into the hone as if you were trying to slice it. Use only light pressure, as the edge is microscopic and pressure will distort it. Make alternate strokes on opposite sides of the blade. When the edge will shave hairs from your arm, it is usable. If you wish, concentrate on one section of blade at a time, leaving the curved tip until last.
BrianFD
Re: sharp knives
Like Ed, I like my Beaver Teeth crock sticks. I've had them for over 20 years, and they always put on a nice thin edge.
