Shallow river inflatable advice
Refleks
I'm looking for an inflatable with a power source to use as an alternative to a ~13' swiftwater raft for rivers with intermittant shallow sections.
In most areas, these rivers are deep enough that an outboard works fine, but then has sections that are 1-1.5 feet deep and maybe the most basic type 1 rapids. The area is often used by tubers and kayakers.
While normally much calmer, there was an instance where 6 people paddling upstream on the raft was only able to keep their station against the current
Instead of the swiftwater raft, I was looking at the Saturn / aleko / bris type inflatables with aluminum floor and transom to mount a small outboard.
It doesn't have to be fast, but being able to make at least walking-pace headway (3-4 mph) against a moderate current (faster than you'd want to simply hop out and walk it across) in the 1-1.5' sections is what I am curious about, with 2 or 3 people onboard.
Is there an inflatable / motor combo out there that could fit the bill? Could I simply lower transom wheels into the water so they'd hit the bottom before the prop does?
Regards
Sea Rider
Too much hassle and precise timing involved lowering wheels before lower leg hits bottom and rising them back when there's enough water bed and so on. All engines have shallow water features, that's pivoting OB to ride at an angle way higher than 90?. Much faster is pivoting OB than raising/lowering 2 transom wheels.
Will need minimum a 12-13 ft Sib with at least a 9.9 HP, 2 strokes are much faster and lighter. Can prop it right to run max wot range with 3 up and gear to perform much better up current.
There's an inflatable keel to consider, some Sib brands have deeper ones, won't know if will hit something when passing through shallow parts while engine is working adjusted to shallow water boating ?
Happy Boating
Refleks
Thank you! Will look into one of the ~13 foot ones and into some motors
Sea Rider
If 2 strokes are still available, might look for a 15 HP, usually 9.9 & 15 weights exact same, a 15 will deliver more power when up current..
Happy Boating
comstox
OK Boyz.... can you say MUD MOTOR??? (Mud-Skipper) Sometimes called "Surface Drives" I am going to get one of these long-tail mud motors for my QuickSilver Inflatable. If I wasn't just a Cadet here or otherwise I would attach a pic. Maybe a link would do? I'll try to attach a link. (Sorry about the music, it's a little over the top.)
Good luck with your quest!
Glen in New Hampshire.
