shaft length
chuck172
I'm looking to buy this used Johnson 8HP. When I asked him the shaft length he said from the plate above the prop to the clamp is 18".
Is this considered short or long shaft. I need a long. I thought short is 15", long is 20"
Scaaty
Re: shaft length
If 18, its for a 15 inch transom..short shaft.
Long shaft would have a 5 inch extension, and mostly used for bigger boats/sailboats, as a kicker...some have 25 inch shafts, strictly (well, mostly) for sailboats
nntw4
Re: shaft length
My 14' aluminium has a 15" transom. We have an old motor that came with our cottage, but it's not a good match.
So, I should shop for a "short shaft" motor with a 15" shaft? Thanks!
Re: shaft length
On an 8 HP engine, that shaft length will not make any difference. If the engine is a good buy otherwise, go for it.
nntw4
Re: shaft length
thanks, but i'm looking for a 15 hp, max the boat can take. think i want a 15" shaft, yes?
nntw4
Re: shaft length
thanks- that's what I figured. I've got a line on a 15 hp 2005 mercury 4 stroke that supposedly has minimal use on it- just have to check it out and then part with the money- just in time for winter storage up here in toronto!
chuck172
Re: shaft length
My 14' aluminum starcraft seafarer measures 17' from the top of transom to the bottom of boat. Not counting the keel.
I have been told I need a long shaft engine (20")
Now this deal comes along on an older Johnson 8hp. The owner measures the motor and tells me its 18" from "the clamps to the plate above the prop"
This confuses the hell out of me. I thought motors are either 20" -long, or 15"-short.
Maybe the owner didn't measure correctly.
Re: shaft length
Ya think??? It could also be that the engine was tilted a little off vertical. That could easily alter the measurement and you have no idea what points the measurement was taken from on either end. Your 17 inch transom would very likely handle either a 15 or 20 inch shaft. I really doubt the 8 HP had an 18 inch length, and if it did, its perfect for you is it not?
chuck172
Re: shaft length
Thats good news that my boat could handle both long and short shaft engines. I was told that with the 17" transom measurement to make sure I get a long {20"} shaft motor.
steelespike
Re: shaft length
Measure the line perpendicular to the keel. will be somewhat less than measured along the actual transom.
