I'm looking to buy this used Johnson 8HP. When I asked him the shaft length he said from the plate above the prop to the clamp is 18".
Is this considered short or long shaft. I need a long. I thought short is 15", long is 20"
If 18, its for a 15 inch transom..short shaft.
Long shaft would have a 5 inch extension, and mostly used for bigger boats/sailboats, as a kicker...some have 25 inch shafts, strictly (well, mostly) for sailboats
thanks- that's what I figured. I've got a line on a 15 hp 2005 mercury 4 stroke that supposedly has minimal use on it- just have to check it out and then part with the money- just in time for winter storage up here in toronto!
My 14' aluminum starcraft seafarer measures 17' from the top of transom to the bottom of boat. Not counting the keel.
I have been told I need a long shaft engine (20")
Now this deal comes along on an older Johnson 8hp. The owner measures the motor and tells me its 18" from "the clamps to the plate above the prop"
This confuses the hell out of me. I thought motors are either 20" -long, or 15"-short.
Maybe the owner didn't measure correctly.
Ya think??? It could also be that the engine was tilted a little off vertical. That could easily alter the measurement and you have no idea what points the measurement was taken from on either end. Your 17 inch transom would very likely handle either a 15 or 20 inch shaft. I really doubt the 8 HP had an 18 inch length, and if it did, its perfect for you is it not?
Thats good news that my boat could handle both long and short shaft engines. I was told that with the 17" transom measurement to make sure I get a long {20"} shaft motor.
