shaft bearing 1962 40hp
bean1969
hi people have found needle bearing under water pump and seal needs replacing. cant see a way of knocking it out from below as nothing to get purchase on. was thinking of using some heat and trying to pull it out using top edge of bearing housing to get some grip.how much heat do i give it? is there another way is this bearing important. thanks
F_R
Honorary Supreme Mariner
Re: shaft bearing 1962 40hp
Don't understand what you mean by bearing housing. I don't believe there is one. Shall we start over with a model number?
BigB9000
Yeah, there is a bearing below the oil seal.
Did you pull the oil seal out already? (Or "oil retainer" )
boobie
Are all the needles still in the bearing ??
bean1969
thanks for all your replies sorry i mean bearing race not housing i have removed seal and bearings arent in place due to part of the top edge of race broke off the model engine is ards 24 but the gear box im working on is off allater model evinrude withthe ball bearings and springs in gearbox. am going to try find some pullers or make somethine to get purchase on whats left of top edge of race and use some heat but if that remaining lip of race breaks off what then? ideas please
F_R
Oh, I see what you mean now. About the only suggestion I can come up with is to get in there with some kind of a grinder to grind away a groove in one side of the race. (Dremel?) It will fall out if you can do that.
Chinewalker
If the gearcase is completely apart (which it should be) then you should be able to come at the bearing from the bottom with something. I've used sockets of approximate size to drive bearings out. Use a socket extension bar to reach in all the way. Hammer on your tools at your own risk - maybe use a rubber mallet or the like.
bean1969
well i found some internal bearing pullers at work and have moved it abit untill bottom lip of race broke off partly going to have another go with some heat using remaining lip for purchase if that breaks then its out with the dremal.gratefull for your replies im sure i will have more questions as my rds24 is not as it should be from what i can see ie different carb no automatic choke so hoses blocked off here an there,anti pop switch not connected wires taped up,already replaced bottom crank seal as this came off with geabox carbon was cracked washer chewed up .just hope i see some life from the engine when im ready to fire it up,.are the fuel pumps on this model okay its the type with glass bowel just was told that smaller
type on later models is better?will it start with the antj pop switch not in circuit i see theres a hose that should be connected to it.i have a rd27a which is complete which my dad bought brand new to cross reference.i bought the 24 because its electric start to go on hjs old wooden speed boat that ive been renovating,whats a good place to buy parts from they seem expensive here in uk they are much cheaper in usa.my carbon seal was 26 pounds.
F_R
Whew, bunch of questions. The fuel pump design is just fine, no need to go changing it. It also is simple to repair, if necessary. The "anti-pop" switch is there to slow the RPM down in case of a runaway condition under no load. Otherwise, it normally does absolutely nothing, and yes it will run without it. But may run wild too.
You might consider making friends with somebody here in USA, and have him send you parts. Postage is not cheap though. You can estimate that by going to www.usps.com
bean1969
will have to read up see how that switch works,will stick with pump then.yeah woulld be good if i could forecast what im going to need and order a bunch of parts to save on postage but obviously need shaft bearing to proceed so i can get it back together stick motor back on tray and try and start it.my reed plate cover has 2 hoses from it both have been blocked off,did one go to the autochoke?is it ok to leave blocked off .the other goes to the switch is that correct, i do have another cover off later model with just the one hose i could fit that perhaps?
