severe chatter when shifting into reverse
scottrbrown
I have a 2000 200hp Saltwater Johnson outboard, and upon starting the engine and shifting into reverse to back out of my boat lift, reverse is insufficiently engaged and chatters severely and noisily. Forward exhibits no problem. However once the engine has been run extensively out in open water the transition from forward to neutral to reverse(to maneuver and control the position of the boat), the chattering/grinding is minimal. it seems most severe and reverse gear engagement most problematic when the engine is first started up. The last time I had it in the shop the report was that the prop was loose. That "adjustment" did not seem to last long at all. Anyone have any ideas?
Bosunsmate
might be out of adjustment if the lower units being off lately.
Otherwise worn reverse gear and or clutch dog. The longer it chatters the more damage thats being done
Honorary Supreme Mariner
Are you shifting with a quick / firm motion?---Are you easing it into gear ?
