I purchased 15 gal. of polyester resin (435 standard from U.S. Composites), and 1-1/2 oz chopped strand mat from them as well, I am doing a lay up over my new stringers which there are five of and roughly 50 ft. in length all together. What is the best way for me to do this, how many layers do I need typically for such a project, do I have enough material? What is the best way to treat the plywood before laying up glass over? Also what is the best way to fix a transom that has rotted plywood interior and damaged fiberglass on both sides. When I fix the transom is it better to fill it with foam or replace with new treated plywood?
Thanks for the previous posts, you guys have helped a lot in a little bit of time!
