setting timing
479665
can someone please talk me through the timing on a 1985 85 h.p. force 3- cylinder. i changed the trigger and have motor running, but still needs to have timing set.<br /><br />all help is greatly appreciated
Bry21317
Re: setting timing
To do this you will need to pull your plugs out (at least you do on the Force 125). then hook up the timing light and then you should beable to get it to time as you would anything else. You will need to people to do it. One to turn the key to crank over the flywheel and one to hold the timing light on the flywheel, or have a remote starter. The plugs are the catch that had me tricked for about a week. I was pulling my hair out about that for days.<br /><br />Hope this helps.<br /><br />Thanks,<br />Bryan Cox<br />MTU
479665
Re: setting timing
thanks bry21317<br />i will give it a try and let you know if it puts me back on the water.<br />i didnt know you had to remove the plugs.
Bry21317
Re: setting timing
Tell me about it. I had never heard of this either, but for my Force 125 I coudln't get it to time at all, and about pulled all my hair out. Then on here I found out you must pull the plugs, and guess what? I timed it perfect in 5 minutes once the plugs were out. I was ready to blow the engine up.<br /><br />Thanks,<br />Bryan Cox
