setting timing on Evinrude 200XP
rick powell
I checked the timing on the motor and it appears to be 6 to 8 degrees off. How do you adjust timing? Motor runs rough at idle but good w.o.t.
HighTrim
Re: setting timing on Evinrude 200XP
How did you check it?
Look at the FAQ and find a thread by Joe Reeves regarding this.
What is your idle set at? Should be 650 to 750 RPM under load in gear. When was the carb last bathed and rebuilt?
rick powell
put timing light on top right hand cylinder, started motor put in gear idling around 800 rpm's. Carbs have recently been rebuilt.
HighTrim
Was the low speed jet removed and thoroughally cleaned? Try a couple tests. Will spraying pre mix fuel into the carb throat pick it back up again? How about choking it?
Here is the link I was talking about before.
http://forums.iboats.com/showthread.php?t=228183
rick powell
I put new jets in everthing cleaned, high speed jets cleaned. Motor acts like it got a miss in it at idle. I've checked spark it's getting a good 7/16 spark on all cylinders, compression test good low 112 high 120.
HighTrim
Spitting back, sounding like a mild backfire, usually indicates a carb slow speed restricted jet..... something causing a lean carburetor scenario.
If you can't find anything wrong with the fuel system, maybe consider a leaky lower crankshaft seal, letting air to the lower cylinder and resulting in a lean sneeze of the lower. Cant really think of anything other than those two.
Dhadley
A very common place for an air leak is the side plates on the carbs.
