Setting the timing 1975 70 HP
carlg53
What is the easiest way to set the timing on a 1975 Johnson 3 cyl 2 stroke outboard enging. I have noticed vibration and it sounds like it may be missing. Can this be done without a timing light? I have noticed a couple of backfires when starting which leads me to believe it could very well be the timing. Thanks for your help.
HighTrim
Re: Setting the timing 1975 70 HP
If you do not have a manual, you should get one. Wise investment. Refer to Joe Reeves thread in the FAQ.
