Hi all, I'm new to boating and iboats now... I've been able to answer a lot of my own questions reading these forums, but have not found exactly what i'm looking for. Question 1 is does the shift cable adjustment affect the idle speed? My boat went in the water for the first time yesterday and I noticed the idle speed in neutral was at 1800 rpm, so it engaged a little rough into gear, the rpm would slow to about 1200 rpm. Rpm in gear should be at 650, correct? Once I am able to get the rpm lowered do I check the timing in gear or in neutral? Can I do that part on the muffs? On a side note, how often should the water separator be changed out? Thanks for any help!
